AC Condenser Unit?? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2014, 06:47 PM   #1
AC Condenser unit??
I have a Lennox Pulse Gas furnace and a 12 seer ac unit. I just installed a Lux programmable thermostat.
Today I was outside cutting the grass and I saw that my condenser fan motor was spinning slow. So I went inside to see if the a/c was on or off at the thermostat, and it was OFF!
So why is my condenser spinning??? Especially if the thermostat is off!! So I turned the a/c on at the thermostat, and the condenser fan did NOT speed up when the a/c was turned on
Do I have a bad fan capacitor?? What's going on here???
thebubba is offline   Reply With Quote
Old 05-31-2014, 07:13 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
You may actually have a very dangerous situation there. The compressor windings may be shorted to the shell and allowing enough current to flow that it partly energizes the fan motor. Has to do with the way the wiring is done if it has a shunt across one side of the contactor and if it has a dual capacitor that does both. Point being DO NOT touch the unit outside as it may be live and you get electrocuted. Get a Pro to check the compressor to see if it is shorted to the shell/ground and find the problem. That furnace is obsolete and has some obsolete parts and should be replaced. I am a Lennox tech and know them very well.
Old 05-31-2014, 07:26 PM   #3
Can I get a compressor for this unit? How much? About $1,000? Or should I replace it?
Old 05-31-2014, 09:04 PM   #4
Hvac Pro
yuri's Avatar
Costs about $2000 or more to replace it. Not worth it as the evaporator or outdoor coil may spring a Freon leak and then the whole unit needs replacing anyway. I would replace the furnace and AC and you can get a much better package price. If you intend to keep that furnace ( I would not, I replaced Moms 2 yrs ago) it should be pressure tested by a Lennox tech to see if the heat exchanger is safe.
Old 05-31-2014, 09:19 PM   #5
Rewards Points: 6,652
Wind or a breeze can cause the blades to slowly spin. Especially if the motor is centered properly and the blade is balanced on the shaft properly.
Old 06-01-2014, 05:56 AM   #6
An old Tradesmen
Rewards Points: 6,550
May have a short in the capacitor. A capacitor shorting to ground an cause this, the same as a grounding out compressor can.
Old 06-01-2014, 07:02 AM   #7
So would it be the capacitor for the fan or the compressor that could be shorting?
Old 06-01-2014, 07:04 AM   #8
An old Tradesmen
It should be a dual capacitor. meaning that both the fan and compressor are both connected to it.
Old 06-01-2014, 07:22 AM   #9
From what I've seen on the unit, there are 2 capacitors. One for the fan, and a large round one for the compressor?
The one for the fan is smaller and oval.
I just ordered a fan capacitor. The darn thing was expensive. Like $36.00. Lol
Old 06-01-2014, 07:26 AM   #10
An old Tradesmen
Would have been cheaper at Graingers.
Old 06-01-2014, 01:44 PM   #11
I have an unrelated question. Why don't we use a double pole contactor instead of single pole to eliminate the dangerous situation like this one ? But people always use single pole contactor, Why ? (the cost is about same)
clocert is offline   Reply With Quote
Old 06-01-2014, 02:57 PM   #12
Hvac Pro
yuri's Avatar
Cost is not the same and when Goodmen etc produce millions of these units and save 50 cents or 1$ it is huge to them.
Old 06-01-2014, 03:48 PM   #13
An old Tradesmen
Even if it was only 10 cents different. That would be $500,000.00 more spent in the year to make the condensers.
Most other appliances also only break 1 leg on a 240 volt circuit.
Old 06-01-2014, 05:40 PM   #14
I see. No wonder I never get rich.
King make up air unit RWolff Electrical 3 04-23-2013 11:22 PM
a/c condenser unit streetman1 HVAC 2 04-23-2012 07:59 PM
Carrier Central Heat/Air Unit acting strangely TheWilldog HVAC 4 02-16-2011 07:42 PM
Help with outside condenser unit cablemn HVAC 5 06-14-2010 04:26 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
