AC Condenser source of ignition?
To my knowledge there is nothing in the code that restricts you from doing what you want to do. The only distance from the exhaust is made to window and dorrs.
I had to place an exhaust 3' over and 2' to the side of a condenser and passed inspection.
Also, a condenser for a heat pump will run were as if yours is just a/c then your condenser shouldn't run for heat.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
