Ac Condenser Pressure Test, Linr Cut, Braze Caps? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 10:18 PM   #1
Rewards Points: 150
ac condenser pressure test, line cut, braze caps?
Is it possible to pressure test a condenser without brazing on caps to cut suction and liquid lines?
Thx
Slash
slash5bmw is offline   Reply With Quote
Old 05-31-2012, 10:22 PM   #2
Rewards Points: 616
not in my opinion.... can not trust valves.......
carmon is offline   Reply With Quote
Old 05-31-2012, 10:52 PM   #3
Rewards Points: 150
So do most valves leak?
If I brazed caps on the lines, I could open the valves and the pressure should still hold.
Unless, you're saying they leak where the allen wrench goes under the service caps.
Old 05-31-2012, 11:03 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
That's what he's saying. There are seals in there, under the head you loosen and tighten, that can leak. Usually they will not leak due to simply being opened and closed. They'll leak because whomever is brazing right there puts too much heat for far more than the neccessary length of time and melt the seals.
No other way to pressure test a condenser. Also, remove the shraeder valve cores before brazing as well.
I'm assuming this condenser has no refrigerant in it so removal of the cores will not deem the service valves need be closed. The valve cores will have to be back in before the pressure test as the service valves will need to be open.
Thanks.
Doc Holliday is offline   Reply With Quote
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
gas-pipe pressure test valve amakarevic Plumbing 7 07-09-2008 01:10 PM
Gas line pressure test smcmurrey Plumbing 7 07-03-2008 11:11 PM
Pressure test water rough-in BillyD Plumbing 2 06-24-2008 02:12 PM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
