AC Condenser Fan Spin - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 09:25 AM   #1
Rewards Points: 77
AC Condenser fan spin
Hello Gurus,
I have a question. In my mind if I set the thermostat at a desired cooling temp, should the condenser fan continuously run until I've hit my set cooling temp? Just a weird question. Don't get me wrong, it appears my AC system is working just great. In fact, it's less than two weeks old, everything, split system. Trane handler and condenser, variable speed motor. I was checking out the condenser fan and noticed sometimes it stops but then goes again. Just didn't know if this is normal or not, even when my set temp has not been hit yet.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 05-17-2012, 10:10 AM   #2
jkv
Do you have a ambient fan control on the unit? It sounds like you do, if out side temp. is low it will shut off the fan so your head pressure can maintain a constant pressure.
jkv is offline   Reply With Quote
Old 05-17-2012, 10:18 AM   #3
Rewards Points: 77
Ah, that's probably it. That makes total sense. Don't know if I have it or not but guessing probably. My system consists of Trane XB13 and handler is hyperion XL TAM7 with the variable speed.
Thanks,
~S
Old 05-17-2012, 05:48 PM   #4
An old Tradesmen
Rewards Points: 6,590
Unless you paid to have an ambient kit added to it, that XB didn't come with one. call the installing contractor back. or start up tech you used if you installed it yourself.
Old 05-18-2012, 08:27 AM   #5
Rewards Points: 77
Thanks. I'll research that.
~S
Condenser fan airflow direction?? nicksab HVAC 8 09-20-2011 10:24 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Washing Machine Not Reaching Max Spin Shelley Appliances 2 11-30-2008 10:12 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
