AC Condenser Electrical-Disconnect Fuse Question?? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 11:10 AM   #1
Rewards Points: 77
AC Condenser Electrical-Disconnect fuse question??
Hello Guru's
Am I doing any disservice to my Central AC Condenser by using 30A fuses in a 30A rated disconnect on a 30A 2P breaker, 10-2 wire? It's a Trane Condenser, only 1 year old.
The side of the Condenser says it's rated for a max fuse size of 25A. Should I switch out the pull fuses from 30A to 25A? Just want to be sure I'm not harming the unit
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 04-11-2013, 11:55 AM   #2
Originally Posted by Skelleyman View Post
Hello Guru's
Thanks,
~S
Well I'm no guru but I'll throw my 2 cents in anyway First of all there's no need to even have fuses in the disconnect if you have a breaker. Just one more thing that can go bad. And I don't see how it would hurt the unit, but really changing a fuse or breaker is really simple & not too expensive I'd think you'd be better off just replacing the breaker and/or fuses to be safe.
JScotty is offline   Reply With Quote
Old 04-11-2013, 12:09 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,764
10-2 wire can handle 30 amps and the breaker/fuses are meant to protect the wire from overheating/melting/damage. If there is a dead short then a 30 amp will pop as fast as a 25 amp. 25 amp breakers are rare and I have not seen any lately. fuses are available in 5 amp increments. May want to post in the electrical forum at the top of the page and see if the licensed electricians think differently. If the compressor stalls then a 30 amp may take 1/2 a second longer to pop and that won't hurt the compressor, just generate a little bit of heat.
Central Air Condenser Disconnect Skelleyman Electrical 15 04-21-2012 11:15 AM
Electrical Question regarding new heat pump poblack HVAC 3 03-25-2012 06:21 PM
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 09:01 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
