AC Condensate Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 10:00 PM   #1
Post
AC condensate issue
I have a Luxaire AC unit in the attic and repeatedly have had the condensate pan fill up, which triggers the safety float and stops the unit from running. We've rarely even used AC this year because we've had a cool summer in the NE. I previously paid a repairman to fix this issue and evidently that didn't work. In addition, when I opened a panel on the unit to check on the filter, I found that there was no filter installed.
So, for you AC DIY experts, a few questions that I would appreciate your help with:
1. What do you suppose is causing the condendate overflow into the pan?
2. If something like a blockage in the unit is causing the overflow, how can I fix it?
3. Is there a reason why the filter would not have been replaced? Could this have contributed to the condensate issue?
4. Is fixing this issue beyond a DYI project so that a repairman should be brought in? Times being what they are, I'd like save a buck.
Thanks!!!
cleddy is offline   Reply With Quote
Old 08-02-2009, 10:26 PM   #2
Rewards Points: 1,088
Thanks!!!
1. Minus the filter, that means plenty of dirt and dust can get to your coil and clog your drain.
2. You'll need to open the panel to access your coil/pan and see what the problem is.
3. See #1.
4. You can do it yourself. If you want to take it a step further and replumb the condensate drain, I recommend adding a clear PVC trap made by EZ trap that has ports that allow you to clean the drain outlet and to keep an eye on the condensate.
http://www.airtecproducts.com/Downlo...structions.pdf
handy man88 is offline   Reply With Quote
Tags
condensate , hvac , luxaire
Purpose of condensate drain/neutralizer sj22 HVAC 11 02-10-2013 02:22 PM
Condensate pump install question kboorman HVAC 6 07-06-2012 08:54 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 08:06 PM
