#1 |
Ac condensate drain lines
I am adding an additional central ac unit. Can I connect the primary condensate drain line to an existing primary condensate drain line? I don't have access to any other drain connection.
#2 |
I would not do it, reason being if one line plugs up your going to have two floods to deal with.
#3 |
Any other suggestions?
#4 |
are you adding it in an attic with the other unit...if so do you have those emergency pans piped out with no trap to a front stoop or back yrad to view if it drips...by having the emergency pans then you could tee over to the exsisting drain line out.units can bang some mean water out on a humid day
#5 |
Yes, the new unit will be installed in the attic along side of the existing units. The emergency over flow lines are piped outside so I can see them.
#6 |
if you have the emergency pans and seperate on the pipes or not any water dripping out B-LINE it you to them thats cool so you could pipe the new unit to the line after the exsisting units trap run out.suggestion on the 2 seperate emergency pans paint the tips of them so everybody knows if wter is dripping call pops....simple seasonal maint.will keep the emergency dry and even flush some water down the pan and trap so the bugs don't cause problems...on the main pans within the air handlers cycling on water reaching in wipe the pans crap and your good to go....
#7 |
i have two a/c systems and both lines join together. the secondary drain lines also join together and are piped to the front porch area. since all systems are supposed to have secondary pans and lines, you technically do have multiple drains and piping both systems together on primary and secondary should be fine.
| Display Modes | |
| Condensate Drain Line Mystery (pan full but no primary clog?) | CarrieLP | HVAC | 21 | 04-05-2012 12:07 AM |
| Trane XR90 - Condensate Drane Trap | JDWorks | HVAC | 16 | 02-07-2012 08:59 PM |
| is it ok to drain condensate to a below slab interior perimeter drain? | steveel | HVAC | 2 | 12-03-2010 06:20 PM |
| Basement *VENTING* AND running entire new drain lines. | 57_Hemi | Plumbing | 6 | 09-30-2010 10:00 PM |
| Condensate Drain Pan Leak | tbfreeland | HVAC | 0 | 09-01-2010 11:34 PM |
