-   -   Ac condensate drain lines (http://www.diychatroom.com/f17/ac-condensate-drain-lines-145313/)
Rick goss 05-30-2012 07:35 AM
I am adding an additional central ac unit. Can I connect the primary condensate drain line to an existing primary condensate drain line? I don't have access to any other drain connection.
joecaption 05-30-2012 07:57 AM
I would not do it, reason being if one line plugs up your going to have two floods to deal with.
Rick goss 05-30-2012 08:08 AM
Any other suggestions?
biggles 05-30-2012 08:22 AM
are you adding it in an attic with the other unit...if so do you have those emergency pans piped out with no trap to a front stoop or back yrad to view if it drips...by having the emergency pans then you could tee over to the exsisting drain line out.units can bang some mean water out on a humid day
Rick goss 05-30-2012 08:39 AM
Yes, the new unit will be installed in the attic along side of the existing units. The emergency over flow lines are piped outside so I can see them.
biggles 05-30-2012 03:11 PM
if you have the emergency pans and seperate on the pipes or not any water dripping out B-LINE it you to them thats cool so you could pipe the new unit to the line after the exsisting units trap run out.suggestion on the 2 seperate emergency pans paint the tips of them so everybody knows if wter is dripping call pops....simple seasonal maint.will keep the emergency dry and even flush some water down the pan and trap so the bugs don't cause problems...on the main pans within the air handlers cycling on water reaching in wipe the pans crap and your good to go....:thumbsup:
NitroNate 05-30-2012 03:52 PM
i have two a/c systems and both lines join together. the secondary drain lines also join together and are piped to the front porch area. since all systems are supposed to have secondary pans and lines, you technically do have multiple drains and piping both systems together on primary and secondary should be fine.
Rick goss 05-30-2012 04:25 PM
Thanks folks. Great help (especially since that would be cheapest and easiest too).
