AC Compressor Replacement? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 05:47 PM   #1
Rewards Points: 14
AC compressor replacement?
I have a six year old Amana central AC unit. It blows ice cold air and seems to be working well. During a spring check-up this week the technician pointed out that the compresser which is rated for 14.4 amps was only drawing 7.8 amps. The outside temp. was 78 f. He said the the low amp draw was an indication the the compresser was failing and should be replaced. System freon pressures were at nominal.
Sounds strange to me. Was he selling compressers or was he right?
Mac
cavers1939 is offline   Reply With Quote
Old 04-26-2012, 06:00 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
I sure would not replace it. Doubtful he checked it properly.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-26-2012, 07:01 PM   #3
Rewards Points: 13,458
Correct me if I'm wrong and I know you guys will, but 14 amp. would be start up amps not running amps. right?
If the compressor is going bad it would draw more amp's not lower amps.
Old 04-26-2012, 07:25 PM   #4
biggles's Avatar
the amp tag on any thing motor or compressor is a rating it should never be at that number..if your Liquid Line was too hot to touch on the hottest of days with the unit running maybe near there.the amp reading on a condenser is related to the head pressure and the inlet are..if you put a water hose on a running condenser and read an amprobe the head would drop along with the amperage.cover the top of the condenser to block the discharged air the pressure rises along with the head.i have servcied semi-hermetic compressors with valve plates and valves in question a trick there is to throttle the discharge servcie valve to see if the head rises worn valves react very slowly to that trick....operating pressures and amperages are on your hottest day with the sun banging the condenser..still not near that compressor rating but maybe 12.0A
Old 04-26-2012, 07:58 PM   #5
Cavers,
Your compressor is fine. Fire that tech and find yourself a new one
Mr.HVAC is offline   Reply With Quote
Old 04-26-2012, 10:07 PM   #6
Rewards Points: 616
Something sounds fishy..... maybe call someone else for next years tune up..
carmon is offline   Reply With Quote
Old 04-27-2012, 05:58 AM   #7
Rewards Points: 1,216
Fire him and never call them again. It hurts the reputable Company's when techs out there do stuff like that. Sounds like he was trying to sell.
In the Spring the Humidity and temperatures are low and there's not much load on the system, less load less amp draw. On 95deg days with high humidity that's when the compressor is pulling the highest amps.
COLDIRON is offline   Reply With Quote
Old 04-27-2012, 06:39 AM   #8
Rewards Points: 582
Mac
the only thing not normal about this is the tech that checked it ...wow scares me to think with some of us close to retiring what our trade my become....... honesty is and will always be the best policy...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
kilosos2 (04-27-2012), Technow (04-27-2012)
Old 04-27-2012, 09:44 AM   #9
Rewards Points: 14
THANKS TO ALL!! I sort of suspected something was wacky, but since I'm not that knowledgable about AC thought I would check.
Thanks Again
Mac
Old 04-27-2012, 12:22 PM   #10
biggles's Avatar
heat effects the system from what is produced or the actual days temp.washing the condenser inside out in aug/july keeps that amperage down$$$$..just check that liquid line on those real hot days the unit heat either rises out the fan or stays on the LL into the air handler..
Old 04-27-2012, 04:09 PM   #11
An old Tradesmen
Rewards Points: 6,932
RLA is only what the compressor should draw while its running at its full rated load. Which is generally at a condensing temp of 130 and an evaporator temp of 45.Most compressors never draw the listed RLA.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-27-2012)
Sash Replacement vs. Insert Window Replacement dcd22 Windows and Doors 15 07-27-2014 04:39 PM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
replace replacement windows theone Windows and Doors 3 10-19-2011 09:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
