Ac Compresor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 11:08 PM   #1
Ac compresor
My central ac compresor trp the bracker
when i disconet the blue wire from contactor then my brecker
is on
MIKE5 is offline   Reply With Quote
Old 06-02-2012, 01:50 AM   #2
Rewards Points: 27
I'm not sure what your seeing can tou check the voltage coming into your unit. You need to make sure that you aren't dropping out one leg of power. Also with the breaker off tighten the wire connection at the unit and breaker. Run the tests and repost.
nunesent is offline   Reply With Quote
Old 06-02-2012, 05:34 AM   #3
biggles's Avatar
on that insulated suction line coming out of the condenser...press the shradder pin down and get some oil and freon on your finger. if it smells burnt the compressor is shot. is the contactor ark'd at all.remove the terminals off the compressor and ohm the termnal to the copper pipe....any read or audible the compressor is grouned....should have a dead short/and or resistance reading between terminals as which is normal
240v Cable Going To Ac Compresor bobo Electrical 1 02-23-2007 05:50 PM
