AC Coils Iced - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2007, 10:42 PM   #1
Rewards Points: 180
AC coils iced
What dos it mean when your AC coils have a thin solid block of ice on them
ocoee is offline   Reply With Quote
Old 09-23-2007, 09:40 AM   #2
Eibwen
Could be the coils are starved for airflow due to either a clogged air filter, failed fan in the air handler, or the coils are really dirty.
Sammy is offline   Reply With Quote
Old 09-23-2007, 10:42 AM   #3
Rewards Points: 180
The coils were very disgustingly dirty
I was able to use a soft hairbrush (wife is out of town) as a coil comb
They aren't icing up anymore but I know I need to do a more thorough cleaning
I have a shedding dog and the filter has been gone since I had work done on the unit two or three weeks ago
I thought he replaced it but was merely assuming
Old 09-23-2007, 10:57 AM   #4
Eibwen
Thats probably it... Dirt will slow the air movement and allow the condensation to build up and then turn to ice.
I have two dogs that shed plus a cat so filters gotta get changed every two months max.
Old 09-24-2007, 05:19 PM   #5
Rewards Points: 180
Been working without the ice since about 30 minutes after your post
Old 09-24-2007, 07:29 PM   #6
Eibwen
Glad it worked out!
Old 09-25-2007, 10:36 PM   #7
Union HVAC Tech.
Loss of air flow or loss of charge are the biggest causes of frosting/icing of coils. Try a coil cleaner like Virginia coil blaster.
bigMikeB is offline   Reply With Quote
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 08:43 AM
