AC Coil Frozen Up - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 05:22 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
AC coil frozen up
I have a 2 ton central air unit for a portion of my house. It has a Zonex 2 zone California Economizer system. Last week it stopped cooling and I was getting little air flow from the registers. Noted the outside refrigerant line was iced up. In the attic I opened the air handler and the coil was frozen solid. Looked at the Zonex control panel and all lights were normal and none of the zone dampers were closed. Shut the system down overnight to let it thaw out. Turned on the next day and it been running the last few days without a problem. Temperatures have been the low nineties for the last week.
Any idea of what the problem was (or is)? I am not an HVAC type but if I have a problem I would like to talk intelligently to the HVAC guy if I have to call. Should I wait and see or call him for an tune-up?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-01-2011, 05:34 PM   #2
Rewards Points: 338
usually that means you are either low on refrigerant or something is restricting good airflow over the coil like a very dirty filter, a blower that isn't working or something else that might be inhibiting flow somehow.
NitroNate is offline   Reply With Quote
Why HVAC people want to replace unit and not coil? pcumming HVAC 4 05-21-2011 10:57 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 06:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
