AC Coil Dripping - Not Going To Collection Pan - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 09:36 AM   #1
ARS
AC Coil dripping - not going to collection pan
The ac coil in my attic air handling unit in dripping down onto the filter flooding the bottom of my box. The condensate is not following the angle mounted coil to the catch pan. Last fall I re-piped the condensate line to ensure proper p-trap per the installation manual. Coil has been cleaned (brushed with shop vac and chemically (spray cleaner from home depot) cleaned.
Any ideas? thanks
ARS is offline   Reply With Quote
Old 06-05-2010, 02:04 PM   #2
An old Tradesmen
Rewards Points: 6,544
Post pics of coil and drain line.
Did you install a vent after the trap?
Old 06-05-2010, 03:24 PM   #3
ARS
Found an answer
Answer: from a different website
The very first thing I would do is to check to make sure that nothing is causing a loss of airflow in the system. If the filter is clean, make sure that all your air registers are open. If those items are okay, coil cleaning is the next step. If that doesn't do it, you may try stepping up the blower speed one level.
Severe sweating is what happens right before a coil starts icing up, so I am going to include what I normally send to people with icing problems.
Old 06-05-2010, 03:50 PM   #4
An old Tradesmen
And do any of those things apply to your system.
Old 06-05-2010, 05:32 PM   #5
Rewards Points: 85
If you over tighten the drain fitting you can crack the drain pan
mikethe ductman is offline   Reply With Quote
Old 06-06-2010, 04:14 AM   #6
You mentioned that you sprayed and brushed the coil. But, did you clean the underside of the coil? The way I am reading this post, the coil is above the filter rack, so this must be an upflow furnace?
Flashheatingand is offline   Reply With Quote
Old 06-06-2010, 04:17 AM   #7
How much space is there between the top of the coil and the top of the supply plenium? Air flow could be the issue also.
Tags
air handler , condensate
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 06:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
