AC Brands - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 08:56 AM   #1
Rewards Points: 326
AC Brands
Hello All
We just found out that our Goodman AC is junk. 0 freon (needs at least 5 to 6 pounds at $85/lb), 9 years old, 10 seer and condenser needs to be replaced. Fix it or replace it. The tech said dont fix it, replace it.
What brands should I consider?
He told me Goodman, as the parts are the same regardless of the the "sticker"
please help,
PTMD
Amitabh is offline   Reply With Quote
Old 07-02-2013, 09:25 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Amitabh View Post
...9 years old, 10 seer and condenser needs to be replaced.
1) The sad truth is that 9 or 10 years has become par.
2) The change out vs fix Q is more about the (R22) gas vs the equipment.
3) Brand... are you a Ford or Chevy guy? (iow focus on the other aspects)
hth
Old 07-02-2013, 09:59 AM   #3
Rewards Points: 326
thank you
ford vs chevy eh.. good analogy, what are the other things to focus on?
Old 07-02-2013, 04:35 PM   #4
An old Tradesmen
Rewards Points: 7,802
Did he pinpoint the leak in the condenser. Or is he just guessing its in the condenser?
Feedback on laminate brands alisonspain Flooring 19 05-03-2013 03:43 PM
Furnace & A/C Brands ldogg HVAC 45 01-04-2013 10:52 AM
Laminate wood flooring brands fdf Flooring 8 08-21-2012 08:25 PM
3 tab shingles - any brands to avoid? aribert Roofing/Siding 9 07-08-2012 02:53 PM
Engineered Wood Floors - good vs bad brands? MOD220 Flooring 4 03-28-2012 10:45 AM
