Old 04-24-2012, 08:06 PM   #31
AC blows hot air
Originally Posted by beenthere View Post
OP. Jumper the R/red wire and the O at the outdoor unit, and see if it gos to cool mode then.
I jumped the R to the O and it turned over into cool mode. So what does that mean?
evan2 is offline   Reply With Quote
Old 04-24-2012, 09:17 PM   #32
Professional
AC blows hot air
That means that you don't have voltage to the O terminal in the HP from the air handler. Same thing we already knew.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
evan2 (04-27-2012)
Old 04-24-2012, 09:55 PM   #33
AC blows hot air
quote=hvactech126;906736]That means that you don't have voltage to the O terminal in the HP from the air handler. Same thing we already knew.[/quote]
carmon is offline   Reply With Quote
Old 04-24-2012, 11:02 PM   #34
An old Tradesmen
AC blows hot air
Now we know that the RV isn't stuck. You may need to run a new thermostat wire bundle to the outdoor unit if you can't find the break in your current wires.
The Following User Says Thank You to beenthere For This Useful Post:
evan2 (04-27-2012)
Old 04-25-2012, 07:39 PM   #35
AC blows hot air
I checked the continuity in the thermostat wires. They aren't broken. I jumped the O and R again, just to double check, it switched to cool again.
I was looking at the wiring diagram; in the heat pump there is a brown T wire that is connected to a tan thermostat wire, but the tan wire isn't connected to anything. Not in the air handler or the thermostat.
Old 04-25-2012, 08:17 PM   #36
Professional
AC blows hot air
T was only used in certain thermostats. How did you go about checking the continuity? Are you sure you had 24V Between O and C at the air handler during a call for cooling?
IT IS WHAT IT IS
evan2 (04-27-2012)
Old 04-25-2012, 09:34 PM   #37
AC blows hot air
hope its not hot there ... if it is call someone ..... you have a easy problem for a trained tec to fix......
The Following User Says Thank You to carmon For This Useful Post:
hvactech126 (04-25-2012)
Old 04-26-2012, 07:47 PM   #38
AC blows hot air
There's not 24 volts between o and c.
Old 04-26-2012, 07:52 PM   #39
AC blows hot air
I checked continuity by disconnecting the r and o at the thermostat, air handler, an heat pump. Tying them together and checking continuity.
Old 04-26-2012, 08:37 PM   #40
kilosos2's Avatar
AC blows hot air
Did anyone tamper with the unit before or you guys made any type of changes? Very odd. Run new wire if you have to!
kilosos2 is offline   Reply With Quote
The Following User Says Thank You to kilosos2 For This Useful Post:
evan2 (04-27-2012)
Old 04-26-2012, 08:53 PM   #41
AC blows hot air
They put a new thermostat on it. I checked it and it's hooked up right.
Old 04-26-2012, 09:03 PM   #42
Professional
AC blows hot air
Well, now you say there is NO 24V between O and C at the air handler. On post #9 you said there was. This would indicate a faulty stat or improperly programmed stat.
IT IS WHAT IT IS
evan2 (04-27-2012)
Old 04-27-2012, 06:09 AM   #43
An old Tradesmen
AC blows hot air
Probably not set up for a heat pump, or set up for the wrong heat pump.
evan2, how long ago was the new thermostat put on. What brand and model number is it?
evan2 (04-27-2012)
Old 04-27-2012, 07:59 PM   #44
AC blows hot air
Yep, the thermostat wasn't set up for heat pump. I reprogrammed it and it's good to go now.
Old 04-27-2012, 08:00 PM   #45
AC blows hot air
Thank you to everyone for the help. I truly appreciate it. God bless.
York Heat Pump - AC blows hot air on cold nights Tpayneful HVAC 0 06-08-2011 08:46 AM
rheem split system blows warm for five minutes then cold queenie HVAC 1 06-15-2009 06:57 PM
Carrier 8000TS Control Bd Fuse blows EAP HVAC 2 08-28-2008 09:07 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
