AC Blows Hot Air - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 07:20 PM   #16
This probably sounds dumb, but I can't find a c wire. Looking at the schematics for the thermostat there is one that is a b/c. Could that be the same? If it is I have no 24 volts between c and o.
evan2 is offline   Reply With Quote
Old 04-19-2012, 08:26 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
that is the same......... SO, you need to find the break in the O wire or if you have an extra wire in the loom you could switch wires both inside and outside and see if that fixes your problem.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
evan2 (04-27-2012)
Old 04-22-2012, 05:50 PM   #18
I switched the o wire out, black for orange, but I still didn't have voltage.
Old 04-22-2012, 06:00 PM   #19
Rewards Points: 616
living Winnipeg I hardly ever see a heat pump.... wish i could help.... I do agree though it apears the reversing valve has either got power when it should not ..does not have power when it should or its defective..
carmon is offline   Reply With Quote
Old 04-22-2012, 06:10 PM   #20
AKA HVACTECHFW
without voltage the RV cant switch to cooling.
IT IS WHAT IT IS
evan2 (04-27-2012)
Old 04-22-2012, 06:15 PM   #21
Rewards Points: 616
well then it should be easy.... either a broken wire or stat no good or stat wired wrong...blown fuse...wires to rv broken .....
Old 04-22-2012, 06:16 PM   #22
AKA HVACTECHFW
yes, it should be easy, but the op may not understand that and may need to call a pro.
IT IS WHAT IT IS
Old 04-22-2012, 06:18 PM   #23
Rewards Points: 616
I agree sometimes more harm than good can be done.....
Old 04-22-2012, 06:44 PM   #24
An old Tradesmen
Rewards Points: 8,236
Good chance the RV is stuck in the heating position. And that its not a voltage problem at all.
Old 04-22-2012, 06:46 PM   #25
Rewards Points: 616
hhmmmmm.... i am learning as well ... heat pumps are scarce here...
Old 04-22-2012, 07:03 PM   #26
AKA HVACTECHFW
The OP stated there was no voltage between O and B/C in an earlier post.
IT IS WHAT IT IS
Old 04-22-2012, 07:48 PM   #27
An old Tradesmen
In post #9 he says there is.
Old 04-22-2012, 08:01 PM   #28
AKA HVACTECHFW
Yes, that is when he checked at the indoor unit. At the outdoor unit he stated there was no voltage.
IT IS WHAT IT IS
evan2 (04-27-2012)
Old 04-22-2012, 08:09 PM   #29
An old Tradesmen
Missed that.
Old 04-22-2012, 08:40 PM   #30
An old Tradesmen
OP. Jumper the R/red wire and the O at the outdoor unit, and see if it gos to cool mode then.
The Following User Says Thank You to beenthere For This Useful Post:
evan2 (04-27-2012)
York Heat Pump - AC blows hot air on cold nights Tpayneful HVAC 0 06-08-2011 07:46 AM
rheem split system blows warm for five minutes then cold queenie HVAC 1 06-15-2009 05:57 PM
Carrier 8000TS Control Bd Fuse blows EAP HVAC 2 08-28-2008 08:07 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 12:00 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
