AC Blowing Hot Air - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 02:12 AM   #1
AC blowing hot air
So i get home frm wk today,open the front door and it feels like a heat wave hit me,,,my unit is blowing out warm air,,,the fan outside runnng and the unt on the insde is running. but no cool air.filters clean.the condensor line on the inside unit arent cool at all.... WHAT IS WRONG?????
mrwright1 is offline   Reply With Quote
Old 06-29-2012, 05:36 AM   #2
An old Tradesmen
Rewards Points: 6,068
Maybe the compressor isn't running.
Old 06-29-2012, 06:26 AM   #3
As beenthere said, most likely the compressor isn't running. In most cases that's not something the typical homeowner can fix. It may be nothing more than a burnt wire or bad capacitor (which some homeowners could perhaps fix), but it's rare that those are the ONLY failures.
Call someone to diagnose and repair the system. If you don't have any experience with a local HVAC company, then call family and friends for recommendations.
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
ben's plumbing (06-29-2012)
Old 06-29-2012, 08:53 PM   #4
It could be low or out of freon. The better units have low and hi side pressure switches that will open the circuit to the compressor to shut off the compressor if the freon level is too low, usually caused by a leak. The freon acts to cool the compressor without the switches in place you could damage the compressor. There might be other safety's in place too or maybe the overload kicked out on the compressor and did not reset. Just my 2 cents...
Kapriel is offline   Reply With Quote
Old 06-29-2012, 09:24 PM   #5
Rewards Points: 582
shut your unit off let set for 1/2 hr restart and listen to hear the compressor start... if you cannot determine if its running or not... may need a tech to check it out....
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 04:03 AM
New AC & Furnace not blowing enough air dficken HVAC 13 07-28-2011 07:21 PM
Cool air blowing, house not cooling helping friend HVAC 3 07-23-2011 08:25 AM
Stops blowing cold air after several hours awathen HVAC 4 06-07-2011 09:31 AM
Hardly any air blowing out vents and lights dim every few minutes girlnamedjo HVAC 7 05-26-2011 01:29 PM
