AC Blower/wheel Assembly Removal - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 10:09 AM   #1
AC Blower/wheel assembly removal
I have a Comfortmaker NTG3100LJG1 AC/Furnace.
I need to remove and replace the blower motor and blower wheel assembly.
Problem: This one doesn't just slide out. It has 2 bolts mounted on the top of each side holding the assembly in place.
The bolt heads are hidden inside the assembly. Only the threaded length is showing.
Is there an easy access to remove the bolts?
xlr8-to-xl is offline   Reply With Quote
Old 06-02-2012, 10:52 AM   #2
As usual I over thunk this one. I only needed to remove the 2 screws in front.
Found my answer here.
http://www.hvac-for-beginners.com/fu...placement.html
Old 06-02-2012, 01:42 PM   #3
biggles's Avatar
it has to slide out to you as you pull on it either the normal 15/16 sheet metal screws or bolts as you have pix is a must for the brain surgeons to advise
GE/Hotpoint clock assembly timer shaft removal Spydey Appliances 0 03-04-2012 12:52 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 03:28 AM
Pop Up Assembly Removal Faucetguy Plumbing 7 10-24-2011 02:34 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
