Ac Blower Motor Cutting In/out - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2014, 09:56 AM   #1
Rewards Points: 16
ac blower motor cutting in/out
got a centurian, model, gf8050b12mu11a, blower motor fan runs intermittantly.6 years old, could just TOUCH control board and all was ok for a few days. same thing , just wiggled board a bit and fan would kick on and run for a few days.all wiring looks good. just changed out the board, getting an error code 9, saysCheck polarity or ground. pulled leads for fan motor off. i seem to have continuity between neutral and either the 3 speed wires(blk,red,blue)... bad motor?
steve1966 is offline   Reply With Quote
Old 08-28-2014, 09:58 AM   #2
Rewards Points: 16
kind of confused, motor seems to have an intermittant short, why no tripped breaker?
Old 08-28-2014, 10:48 AM   #3
Rewards Points: 3,256
You should have continuity between those fan leads, pretty low resistance also. Any of those with resistance to ground would be bad. From your information I don't think there are any problems with the motor.
I remember reading a post not too long ago somewhere about a polarity error but I can't remember the details. Maybe it's talking about the 24 volt control transformer? It is AC but sometimes one lead is run to ground. One of the pros can most likely help on the polarity issue.
zappa is offline   Reply With Quote
Old 08-28-2014, 01:17 PM   #4
Rewards Points: 16
im getting intermittent continuity from the 3 power leads (red/blk/blue) to ground, but the fan runs at times for a little while . but im not blowing board fuse or tripping breaker?
Old 08-28-2014, 09:42 PM   #5
Rewards Points: 225
If you weren't getting the error code before you changed out the board and now you are after you replaced the board then you may have something wired incorrectly... Double check and confirm that everything is wired properly. Make sure your transformer is wired correctly on the primary and secondary.
a.man1302 is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Carrier Blower Wheel Failures AzJeepguy HVAC 8 08-03-2014 03:09 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 08:44 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
