Old 09-13-2008, 09:36 PM   #1
ac blower
My blower motor comes on then goes back off running no more than a few seconds. The blower spins freely by hand so I think the blower motor is good. Could it be a starter soelnoid of something like that. I changed the batteries in the thermosat and checked for loose wires finding nothing loose. The outside unit runs and responds as it should but the inside blower will not stay running either in "auto" or "on" mode. It's actually my mother's ac and she is 90, I put in a call to a a/c service company but maybe they don't work weekends and I would like to get it fixed before it gets too hot.
Geo60 is offline   Reply With Quote
Old 09-14-2008, 07:36 AM   #2
Whatamess
ac blower
When it blower quits feel the motor housing and see if it is hot. Sounds like the overload on the motor is tripping due to some problem. If that is the case you can take it to a motor rebuild shop or replace it.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-14-2008, 08:04 AM   #3
ac blower
Thanks, I will check that today but I believe that this also happens even when the unit has been off and the motor is cold.
Thanks, Geo60
Old 09-14-2008, 08:27 AM   #4
Whatamess
ac blower
Thats the point. It may be a start switch / winding or capacitor problem causing the motor to overheat. It will do this very rapid.
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Blower Doesn;t Work - But Does!! fauer Automotive Repairs 3 06-02-2008 05:31 PM
Looking for blower motor capacitor dditch66 HVAC 3 11-26-2007 08:35 PM
Blower control board mlmaher HVAC 1 11-24-2007 02:39 PM
