Old 09-20-2007, 05:44 PM   #1
Default To AC Basement or Not?
I have an old rowhouse 700 sqft each floor in Wash DC. I am installing central air into the 1st and 2nd floor. The question is should I run ductwork into the basement aswell? The condenser / air handler are going to be on/in the roof/attic respectively. 1st and 2nd floors with have ceiling vents.
I want the basement to be livealbe space, a small office and maybe watch movies down there too. I want to remove as much humidity as possible to prevent mold growth and even throw carpet down there if possible. I have allergies to mold.
In order to run ductwork down to the basement it will be an extra 0.6k to 1.0k
Ductwork to the basement will also mean sacraficing more closet space.
If I run ductwork it would be difficult to have a vent and return that are far from each other then might only be 10 to 15 ft away.
Contractors have suggested combinations of:
1. do nothing to the basement
2. put a few dehumidifiers in the basement
3. put a central dehumidifier in the basement
4. put dehumidifiers and a window AC unit in the basement.
5. put a duct vent in the basement
6. put a duct return in the basement
7. put both a duct vent and a duct return in the basement.
8. only have one return for the whole house at the top of the stairs on the 2nd floor.
What should I do?
I want my basement to be quiet, comfortable, and mold free.
Thanks in advance for your kind assistance.
jacko10 is offline   Reply With Quote
More On This Topic
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
In a pinch, you can use a ventilation shaft for making an emergency exit from a large building. As long as you aren't given to claustrophobia, and don't end up in the boiler room by mistake, a ventilation shaft makes an excellent escape route. Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 11:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 11:55 PM
Epoxy in the basement jkrodger Flooring 1 07-20-2007 12:27 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 09:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 10:09 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
