Ac Always Running - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 05:47 PM   #1
ac always running
Can anyone tell me why my condenser fan and compressor run continously? My set point is set to 76 and the temp. reads 73. I had just replaced the motor to the condenser fan and the control module/board in the furnace box. Is it the T-stat or a bad wiring job on my behalf?
jerick is offline   Reply With Quote
Old 06-07-2011, 06:01 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
you may have a constant 24 volts from the furnace or the stat to the condenser. the red and white wires, usually used from condenser, do not go on the r terminal of either the stat or the furnace, furnace usually being where they are tied into and not the stat. the blue or yellow coming from the furnace to the y terminal of the stat, the cooling terminal which brings on the condenser, does not go onto the r terminal.
r is constant power.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
jerick (06-07-2011)
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 12:09 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 09:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
