Old 12-06-2012, 10:00 PM   #1
Abandoned return air vents
An HVAC contractor installed three new cold air returns. The previous existing ones are no longer connected to the furnace. I want to install blanking plates but my wife wants to leave things as they are. I think this is a mistake since dust from the crawl space will come up and enter the rooms through the grilles, all wall mounted.
Am I correct? Need some ammunition!
Ogopogo is offline   Reply With Quote
Old 12-07-2012, 05:02 AM   #2
An old Tradesmen
Seal them. Or have them reconnected. Leaving them open is one of the worse things you can do.
Old 12-07-2012, 06:24 AM   #3
Items wanted: Time
Consider the bugs that now have an open door to your home.
NiNe O is offline   Reply With Quote
Old 12-07-2012, 08:28 AM   #4
seal them up...now go fire away....oh btw...good luck with wifeyben sr
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing 3 05-11-2012 11:56 AM
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 03:39 PM
Closing off HVAC return and supply vents Kulingar HVAC 6 11-15-2011 10:22 AM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 09:30 PM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
