95% Ducane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 11:01 AM   #1
95% ducane furnace
I just had a 95% ducane furnace installed. along with a new thermostat wire and thermostat. The furnace refuses to run the way I think it should. It shuts off usually in the middle of the night and wont come back on without turning power off. it goes out on two codes either pressure switch open with inducer on(code 3) or pressure switch cycle lock out(code 6). and the furnace wont stay on until the set point on the thermostat is reached either.
peanutt710 is offline   Reply With Quote
Old 12-08-2010, 12:31 PM   #2
Rewards Points: 1,580
Why not call the installer back to fix it? It must still be under warranty?
bob22 is offline   Reply With Quote
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 04:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ducane furnace does not light. uncleshah HVAC 7 02-08-2009 06:44 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
