Old 12-31-2011, 06:54 PM   #1
9200 Furnace issue
My 9200 Carrier furnace will not come on. When i flip the electrical switch off and then on the blower motor comes on for about 3o sec and cuts out. i turned off everything per instructions and turned back on. Nothing happens. The blower motor was replaced a couple of years ago. The ignitor was replaced 3 years ago. any suggestions?
matt williamson is offline   Reply With Quote
Old 12-31-2011, 10:26 PM   #2
9200 Furnace issue
I had a similar issue with my oil furnace. In that case it was the transformer that supplies the power to the ignitor.
You mention a blower, are you talking a power vent blower for the exhaust, or the air handler blower? If it's the exhaust blower, the sampling tube that measures the speed of the exhaust to make sure the blower is running, can get clogged, and the furnace will do that as well.
Hope this helps.
Bill
Billbeas is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace pressure switch issue darylzero HVAC 28 11-19-2011 07:52 PM
Weather Maker 9200 Furnace benoy HVAC 5 12-07-2009 09:03 PM
carrier furnace and honeywell zone control issue bmccarron HVAC 14 09-20-2009 10:59 AM
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 10:08 PM
