90% Furnace Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 09:26 AM   #1
90% furnace vents
what would make my funace vent drip water back into the furnace housing a flood the floor?
Rmdsr is offline   Reply With Quote
Old 12-12-2010, 09:37 AM   #2
fabrk8r
fabrk8r's Avatar
Plugged or improperly plumbed condensate piping.
Water is a byproduct of the combustion of natural gas and 90%+ NG furnaces have to be piped for this condensate because the flu gases are too cool to carry the moisture out of the vent.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
Rmdsr (12-12-2010)
Old 12-12-2010, 09:39 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
where is the water coming from? 90% furnaces produce condensation in the flues and secondary heat exchanger. Furnace should have a drain line. If condensate is coming from flue fitting or joint, then it wasn't primed and glued properly. It's also possible for the trap in the furnace to plug up
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-12-2010, 09:40 AM   #4
fabrk8r
fabrk8r's Avatar
It sounds like the tube from your vent fan may be plugged if the condensate is leaking inside the unit. There will be a small, usually black (sometimes gray) fan housing inside the burner compartment. Check the small flexible hose coming off the bottom of this fan for a restriction.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
"Perfume" Smell from Furnace Vents Doc HVAC 6 12-29-2007 02:19 AM
