90 Degree End Of Lineset?? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2007, 06:13 PM   #1
90 degree end of lineset??
hello.....i am doing most of the work installing air handler/condenser, etc...then have a pro do the hookup and startup. my question is on the lineset...it has a 90 degree 6" end and a straight end. where would the 90 degree end go. my air handler is in the attic, so the lineset goes up the outside of the house. the 90 degree end would fit nicely in the hole in my wall then lay flat down to the condenser. otherwise isn't it difficult to bend this line 90 degrees?
thanks
davidc is offline   Reply With Quote
Old 05-25-2007, 06:23 AM   #2
It doesent have to go anywere, its there for convience sakes, if you dont need it it can be cut off............honestly 9 out of 10 times it does not get used.
harleyrider is offline   Reply With Quote
Old 05-25-2007, 12:46 PM   #3
ok...thanks, i'll use it at the entrance to the attic, then add on from there to the air handler.
4 inch 90 degree PVC elbow w/2 inch heel inlet amakarevic Plumbing 5 07-27-2007 06:59 PM
45 degree calculation jmako Carpentry 2 07-10-2007 09:15 AM
Will a 4T Evap. Coil w/50' Lineset suck in 21 oz R22 at 500 microns? hennyh HVAC 1 02-21-2007 11:49 AM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 11:10 AM
