-   -   90 degree end of lineset?? (http://www.diychatroom.com/f17/90-degree-end-lineset-8654/)
davidc 05-23-2007 06:13 PM
hello.....i am doing most of the work installing air handler/condenser, etc...then have a pro do the hookup and startup. my question is on the lineset...it has a 90 degree 6" end and a straight end. where would the 90 degree end go. my air handler is in the attic, so the lineset goes up the outside of the house. the 90 degree end would fit nicely in the hole in my wall then lay flat down to the condenser. otherwise isn't it difficult to bend this line 90 degrees?
thanks
harleyrider 05-25-2007 06:23 AM
It doesent have to go anywere, its there for convience sakes, if you dont need it it can be cut off............honestly 9 out of 10 times it does not get used.
davidc 05-25-2007 12:46 PM
ok...thanks, i'll use it at the entrance to the attic, then add on from there to the air handler.
