90 Degree Elbows In Central Air Line Sets - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 10:33 AM   #1
90 degree elbows in Central Air line sets
I am installing my own replacement central ac condensers and evaporator coils and I will be moving the outside condensers much closer to the evaporator coils. My question is, can I install 90 degree elbows in the line sets that I run from the condensers to the coils?
Thanks for any replies.
bfsjr is offline   Reply With Quote
Old 04-10-2010, 10:43 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Yes. Long radius are the best and you should have at least 15 feet of lineset between the condensor and indoor coil or problems can occur.Read this post for more useful info and links:plumbing copper for HVAC refrigerant lines?
The Following User Says Thank You to yuri For This Useful Post:
bfsjr (04-10-2010)
Old 04-10-2010, 03:05 PM   #3
An old Tradesmen
Rewards Points: 6,886
And please don't soft solder them.
Old 04-10-2010, 06:58 PM   #4
90 degree long radius fitting in central ac line set
Beenthere,
Thanks for your reply to my question and if I may ask you another. I will either braze the fitting or possibly use the HVAC super pro but, is there a limit as how many of these fittings I can use between the condenser and the evaporator coil? My total run for the line set will be from 25 to 50 feet.
Thanks again
Old 04-10-2010, 08:03 PM   #5
An old Tradesmen
Each ell will add 3 to 7 foot of equivalent length. Depending what size the ell is.
So yes. You can have too many ells in a line set.
How many ells you gonna have.
Old 04-10-2010, 08:48 PM   #6
Thanks Beenthere.
After much study on this topic, I've decided to make 90 degree bends to the line set rather than to make the bends with long radius elbows. At least that way I won't be bothered with leaks and pressure restrictions.
BFSJR
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
Adjusting for Elbows in Gas Line Clutchcargo Plumbing 3 10-01-2007 01:05 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
