70 Degree Supply Air - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 07:43 AM   #16
I know there's a lot of people commenting here. From reading some of the posts and the original post. I get the feeling the area is too large for the Cooling unit being used. Too much heat gain from attic, and other places. Also in one of the posts Ryanxo he had mentioned the supply air gets down to 60 degrees or so. And has never been right in the two years he's had it. I think there's more here. Who knows what is running inside the house, TVs, oven, lights, computers,etc. It's possible this set up will never cool the load. It's not that much tonnage to start up with.
Just a tought...
Kapriel is offline   Reply With Quote
Old 07-01-2012, 08:00 AM   #17
An old Tradesmen
Rewards Points: 6,462
Its one ton per 600 sq ft.
Old 07-01-2012, 08:03 AM   #18
Ok,
What's the real load ?
Old 07-01-2012, 08:05 AM   #19
I think the real load might surprise us.... Just a thought from an old timer.
Old 07-01-2012, 08:08 AM   #20
An old Tradesmen
His insulation could be carry enough that it needs a 2.5 ton. Its always better to improve the house envelope so that the smaller unit can handle the load, instead of just putting in a larger unit. His return could be pulling in attic air.
Electric isn't 3 cents a KW anymore.
Old 07-01-2012, 08:11 AM   #21
Food for thought,
I put a 6 ton portable AC unit the size of a refrigerator in a computer room
the size was about 12' X 12' the size of say a bedroom.
6 tons couldn't cool the load and humidity was not a problem. The building was already being cooled. The power supplies for computers put out heat like an electric heater. Anyways I could be wrong about the size thing would'nt be the first time.
Old 07-01-2012, 08:13 AM   #22
I still remember my grandmother trying to cool down her 95 degree kitchen
by leaving the refrigerator door open....... she said it helped.
Old 07-01-2012, 08:31 AM   #23
An old Tradesmen
Food for thought,
I have 12.5 tons in a smaller computer room. on days above 95, it barely handles the load.
If the OP comes back and says he's running a server or 2 from his house, then yeah, he needs a larger unit.
Old 07-01-2012, 08:41 AM   #24
It's amazing isn't it.....
I hooked up a 25 ton Voyager to a room 25' X 25' it started to cool the room but took forever to cool it just a few degrees. Condensate waste pouring out of the trap just one of those days.
Another job I hooked up a 75 ton Intellipak to buildings ductwork. It was pouring out condensate but only added a few degees cooling.
Both units work fine in our shop I tested them before sending them out.
I cannot control the customer's infrastructure.....
Old 07-01-2012, 10:19 AM   #25
An old Tradesmen
That s the nature of commercial.
Old 07-01-2012, 11:54 AM   #26
Didn't see anybody post anything about how close to design temp the ODT was.
Getting a lot of units struggling here cause the heat load has surpassed our local 95* design criteria.
That the OP has other service symptoms I am not disputing. But the main cause is it's just too damn hot.
hvac5646 is offline   Reply With Quote
Old 07-01-2012, 12:10 PM   #27
heres a thought: Uncle runs a sprinkler on condensers to help increase capacity on at or above average design temp days.
Old refer man's trick, I am told.
Old 07-01-2012, 02:33 PM   #28
Are you serious ?
Old 07-01-2012, 02:45 PM   #29
Rewards Points: 6,652
Are you serious ?
Yep. Keeps the coil cooler, thus allowing for the freon to be cooler, in turn allowing cooler air blowing across the a-coil.
No matter how hot it is outside, the air temp coming across my A-coil is always between 42-48 degrees farenheit.
Old 07-02-2012, 03:55 PM   #30
ryanxo's Avatar
Wow. Thanks to all for the overwhelming responses. There are so many suggestions I don't even know where to start. Ok thats a lie I can start out by saying yea I'm an IT guy but NO i am not running a server farm in my house. The only desktop computer we have is in my room and it's not on very often and def not during the day because yes it heats up my room and my room is the hottest one no matter what. I've worked in server rooms... i know how much heat they pump out lol.
My insulation is about 6 inches thick in the attic. I have 3 gable vents. 1 of which has a fan in it. And I have an attic fan coming out of the top of the roof. Both come on when it hits 90 up there.
The heat the past few days has been damn hot. like 98 + with heat index of 104 so thats when i reallly noticed it struggling. It would be set on 74 all day and by 6pm it was 78 in the house.
I have checked and sealed my return... it is zip tied, mesh taped and masticed, as well as aluminum taped over that. If there is any attic air being sucked in well it's ninja air and no one can stop it.
I'll check the temp at the air handler and get back with results. ugh 125 degree attic temps.... i never wanna be up there again but I guess i have no choice.
Is it ok to wrap the air handler in insulation? After taking the side panels off I noticed that it doesnt have much inside of that thing. Would that help?
I'm still concerned that the air coming out of the condensor outside isn't hot.
I'm going out of town this week for 4th of july but as soon as I get back on Sunday I'll be back at it. AC guy can't come today so he is coming next monday when i get back.
And as for spraying the condensor... I did that a few times hoping it would help... hell I even sprayed the roof with the water hose on Saturday to cool the attic down. Didn't really help just made some cool looking steam. Who's idea was it to put dark asphalt shingles on rooves anyway?!
I am not an expert in anything. Any advice you take from me is strictly at your own risk!
ryanxo is offline   Reply With Quote
Cold Refrigerant Line...Warm Supply camryman95 HVAC 7 06-30-2011 06:29 PM
combustion air grills near supply vent? denemante HVAC 2 05-09-2011 04:22 PM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 09:30 PM
Rerouting stack and water supply for an added beam WillK Plumbing 1 03-02-2011 09:27 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
