Old 08-06-2012, 12:53 PM   #1
Question
60 ton Trane rooftop unit Model SAHA 600...
I am looking for schematics, system operation, and any other supporting documents for a 6 ton roof top unit.
Model SAHA6006OJ74A74ADG0
Serial B81J04057
I have waited on Trane for 3 days and really need the information? Any help that you can give would be appreciated.
Thanks,
RTG
RTG Service is offline   Reply With Quote
Old 08-06-2012, 04:51 PM   #2
Only one unit no others on the roof like and kind you can look at?
COLDIRON is offline   Reply With Quote
Old 08-06-2012, 10:50 PM   #3
Professional
http://www.google.com/url?sa=t&rct=j...GaXWphNq-nW52A
https://docs.google.com/open?id=0B0n...01TMXY3N1BBdUE
https://docs.google.com/open?id=0B0n...Et0WkxwUGJlLTA
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-07-2012, 07:24 AM   #4
Coldiron: I called Trane and they ran the serial #....? Apparently there are only 2 of these in the nation, both prototypes?
Thanks for the reply.
HVACtech 126: Thanks for the schematics, that is more than I was able to come up with. I tried gaining access to comfortsite.com but the hassle was not worth the wait. I will use the information provided along with a little common sense and hopefully I can get the unit up and running? Have a great day and thanks for your time.
The Following User Says Thank You to RTG Service For This Useful Post:
COLDIRON (08-07-2012)
Old 08-07-2012, 07:31 AM   #5
biggles's Avatar
1981 might have a W973 Honeywell gray boxed controller running off zone temperature and a DC voltage ramping of that controller for heating and cooling.possibly 2 semi-hermetics Tranes first large tonnage rooftop product.might have a max of 4 stages of cooling with electric unloaders with economizer control also off that W973 thru an enthalpy sensor in the outside air chamber..first thing to change if your looking to do econo cooling(most weather out rusting up)
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 5 08-07-2012 02:53 PM
trane model and serial number joester HVAC 0 06-22-2012 11:04 AM
Trane Residential Unit w/Heat Pump Eddie Luna HVAC 1 06-21-2011 03:38 AM
Bryant AC UNIT MODEL #561CJ036F dabody1969 HVAC Site - PROS ONLY 0 07-16-2010 08:09 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
