-   -   6" Air Duct Collar for wall pass through (http://www.diychatroom.com/f17/6-air-duct-collar-wall-pass-through-171970/)
bee-man 02-14-2013 10:22 PM
Hi all,
I am installing an over the range microwave oven, and need to run a 6" exhaust duct through the wall above the kitchen cabinets. Since I have a whole house fan, I would like to maintain a good seal between the living and attic space. I found these air duct collars which would work perfectly for my needs. However, I am not sure what problems this could potentially introduce (vibrations, noise, hazards???). Have any of you used this or something similar when running a duct through a wall?
http://www.ideal-air.com/products/du...air-tight.aspx
carmon 02-14-2013 10:40 PM
not sure it helps you...still need to seal it...... just seal the pipe ....
TarheelTerp 02-14-2013 10:48 PM
1 Attachment(s)
Originally Posted by bee-man (Post 1117426)
I am installing an over the range microwave oven and need to run
(an exhaust duct of some sort)
... above the kitchen cabinets.
...and then through the attic space and in turn OUT of the house through the roof.
There are several duct shapes to choose from.
And they'll all need a starting collar like in your link.
If the duct is actually going to be IN the wall I suggest that a rectangular shape (approx 3.25" x __") will be easier to fit behind the sheetrock.
Once above the ceiling and into the attic... other changes can still be made until you finally adapt to the roof vent cap:
bee-man 02-15-2013 03:27 PM
Hi,
I will absolutely seal the duct junction. However, I need to maintain a good seal between the attic and living space since the positive pressure from the WHF will push attic air through any leak. Right now, plan B is to use a foam sealant around the duct (not to seal the duct junction) but it is more messy and possibly prone to leaking after time. In my eyes, using the collar with flange on the wall will allow a good seal between living/attic space, and provide a solid mounting point for my ductwork. However, I am not sure about the negative impacts.
TarheelTerp:
The path of my ductwork is not ideal. After going through a single sheetrock panel (via 90 degree elbow), it will make a 12 ft horizontal straight run through the attic to a Broan 641 wall cap. This is still under the minimum effective length specified by the manufacture. I am slightly concerned about grease build up, though, but I'm willing to try this before resorting to other measures. The OTR microwave fan is rated at 400cfm, but that is probably rosy. Thanks for the info on roof caps.
beenthere 02-15-2013 04:42 PM
12 foot through an attic? Better insulate that pipe.
bee-man 03-16-2013 12:18 PM
4 Attachment(s)
This is just a closing post of my solution.
