Old 03-06-2008, 11:12 AM   #1
$59 "vent free" heater for garage?
I saw these on Northern Tool. I thought it would be nice to heat the garage in the winter when I am sometimes doing projects there. Basically somewhere I can make a mess, assemble stuff, without freezing my hands off. This would only be when I'm working there and generally if this is the case, it means nobody else is home. Regardless, the problem is the garage is underneath the living room. I don't like the idea of whatever fumes going up and into our home. Thoughts?
pcampbell is offline   Reply With Quote
Old 03-06-2008, 08:13 PM   #2
hvac/refrigeration
For starters carbon monoxide doesn't necessarily rise. If you are talking about the Mr.Heater it will be fine in the garage while you are working.I would not trust them in a bedroom while sleeping though.
metal-maniac is offline   Reply With Quote
Old 03-26-2008, 03:24 PM   #3
Your best bet is an electric garage heater.
Clean, safe, easy heat.
Last edited by stitch; 03-26-2008 at 06:26 PM. Reason: Removed rule-breaking link.
stitch is offline   Reply With Quote
Convection Heater flyultralite Electrical 3 02-15-2008 01:34 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
