50 Amp Panel And Wants A/c Installed - HVAC - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 09:56 PM   #1
Rewards Points: 99
50 amp panel and wants a/c installed
Got a customer who wants a/c installed in her mobile home. She'll probably need 3 tons of cooling. Anyone ever tried it with only a 50 amp panel? Dryer and stove uses gas.
Apparently upgrading the panel is not feasible.
I'm 99% sure of the answer which is a definite no but always like to cover my bases.
Thanks for any help.
kirwinjd is offline   Reply With Quote
Old 05-27-2013, 10:26 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Only two way you can do this .,
A) run the A/C feed from the meter pedestal which I know it is legit in some area.
B) tell the customer end up put in a 100 amp panel and run new MHF ( Mobile Home Feeder ) cable from meter pedetal to the new load centre. This useally done by liscensed electrician.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
ben's plumbing (05-28-2013)
Old 05-27-2013, 10:29 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
3.) tell her to buy a 120 volt window unit.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-27-2013, 10:34 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
3 tons for a "mobile home" aka, a trailer.
How big is this mobile home?
sublime2 is offline   Reply With Quote
Old 05-27-2013, 10:41 PM   #5
Intertherm and Stylequest are both mobile home hvac manufacturers. Their systems all go to 5 ton. I've installed systems in mobile homes bigger than many regular homes.
Thanks.
Old 05-27-2013, 10:44 PM   #6
Did ya ever see straight electrique heat HAVC unit the last one my customer called me some time back end up have to install seperated 100 et 200 amp services due the HVAC electrique heating elements.
Old 05-27-2013, 10:48 PM   #7
Rewards Points: 99
Merci,
Marc
Any idea what this might cost? Hundreds? Thousands?
Not sure what you mean by meter pedetal and new load center. Not being an electrician, I would assume we would need to upgrade the panel and pull bigger wire from the panel to a new transformer on the pole which means calling in the utility company.
Old 05-27-2013, 10:51 PM   #8
Rewards Points: 99
Thanks. You might be right. I was going to recommend a 2 ton 220vac mini split
Old 05-27-2013, 10:53 PM   #9
Rewards Points: 99
Mobile home is a double wide, about 60 feet long and has a Coleman furnace with a 3 ton blower which means I have to size the coil and condensing unit accordingly
Old 05-27-2013, 11:09 PM   #10
The load centre mean breaker box or old fuse box if still have it.
The meter pedestal mean a outdoor meter socket which it will be standing on it own main breaker to feed the mobile home.
For the transfomer itself most case POCO do not bother change the transformer until it burn out or hevey load keep blowing the fuse ( very rare ) due they can take a bit of overload before they blow the lid.
But the costwise that will varies alot depending on how the load centre is located plus the meter pedetal is.
Note: if you have POCO pole that will work as well due that is your main point as well.
Merci,
Marc
Old 05-28-2013, 04:20 AM   #11
Rewards Points: 1,016
High SEER mini-split.
____________
Vince
Old 05-28-2013, 03:00 PM   #12
An old Tradesmen
Rewards Points: 6,932
Merci,
Marc
Commonly done here.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (05-28-2013), frenchelectrican (05-28-2013)
Old 05-28-2013, 05:50 PM   #13
Rewards Points: 79
Just because the furnace can handle up to three tons doesn't mean you have to use it all. Do the load calc install the right size then adjust the airflow to the size.
Ebierley is offline   Reply With Quote
Old 05-28-2013, 09:40 PM   #14
Rewards Points: 1,192
Double wide on a 50 amp panel? Take another look.
bobelectric is offline   Reply With Quote
Old 05-30-2013, 10:17 PM   #15
Rewards Points: 99
I did. The park manager confirmed it.
