5 Ton Goodman - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 06:03 AM   #1
5 ton goodman
i got a really good deal on this unit but my ductwork is not designed for it.im making a new truck line today from sheet metal how big does it need to be to get the right airflow?i live in a double wide 26x48 i recently built a 24x36 garage with a full upstairs.approx 3000 sq ft. ill be running flex to the registers have different sizes of flex just not sure how the most efficent would be
frank2nikki is offline   Reply With Quote
Old 08-07-2011, 08:42 AM   #2
Rewards Points: 6,652
About as efficient as our politicians in D.C..
Old 08-07-2011, 09:13 AM   #3
Experienced
Jackofall1's Avatar
How big it needs to be is realitive to the Manual J & D calculations you did.
OH you didn't do that....Hmmmmmm.....had you done that, you would have found that a 5 ton unit would not be suited for your installation......or maybe you need 10 tonnes.
The point being what you are asking is absolutely impossible to answer, duct sizing is based on comprehensive calculations for heat loss/gain with the results being converted into, CFM per room based on the load.
Mark
Old 08-07-2011, 11:11 AM   #4
An old Tradesmen
Rewards Points: 6,074
How big depends on the total length, including the equivalent length of all fittings. So on a single trunk system, 12X32 could be the right size.
Probably would have been better 2 have one unit for the space above the garage, and one for the existing structure.
Old 08-08-2011, 04:05 AM   #5
i know the unit is too large but for 75 dollars couldnt pass up and yes if it had been a ten twenty or whatever tons for a stand alone system for $75 sorry didnt see a need for a calculator.did go with 12x36 trunk @40 ft long 10 registers ,2 10 in flex 4 8ft flex ,4 7in flex,with three returns 2 14x14 carried by 12in flex and one 17x21 carried by 15in flex they meet up in a 24x48 box i built in front of unit under floor.hope to complete today will post results.also left top story out maybe a ten ton unit might come my way
Old 08-08-2011, 05:42 AM   #6
An old Tradesmen
Around here, a place your size would need maybe a 3 ton system. So your 5 ton may leave you with a high indoor hum idity.
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 03:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-26-2007 12:37 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
