5-ton Condenser On A 4-ton System Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 08:56 PM   #1
Lightbulb
5-ton condenser on a 4-ton system question
I have a 4-ton Lennox system. The condenser unit needs replaced but all else is good. Does anybody see any issues with using a 5-ton Goodman condenser with the existing 4-ton system? I am just looking at getting the house cooled for one or two more seasons until I can replace entire system with something newer.
gramoca is offline   Reply With Quote
Old 05-15-2009, 10:12 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 148
The 2 have to match or the condensor will run weird pressures and ice up the indoor coil etc etc.
Old 05-16-2009, 07:30 AM   #3
What's wrong with the condenser unit? If you are going to all that expense to just throw it away in 2 years, why not just fix it.
dac122 is offline   Reply With Quote
Old 05-16-2009, 09:41 AM   #4
An old Tradesmen
Rewards Points: 7,816
Doubtful your moving 400CFM per ton for you 4 ton unit.
So, you'll have low airflow for a 5 ton.
Probably end up freezing up the indoor unit. And wiping out the compressor of the 5 ton.
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
Should I Do Sprinklers + Drip System? jbk Landscaping & Lawn Care 5 02-12-2009 06:48 PM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 09:14 AM
Question about septic system...... randalg Plumbing 7 03-21-2008 01:43 PM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 10:05 AM
