5" Filter To Replace 1" Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 03:31 PM   #1
Rewards Points: 280
5" Filter to Replace 1" Filter
Has anyone ever used this Honeywell 5" air filter to replace a standard air return grill 1" filter? I tried to find it on the Honeywell site but could not.
http://www.filter-outlet.com/product...product=112922
Earnie is offline   Reply With Quote
Old 12-27-2010, 05:56 PM   #2
U have to have a five inch filter grille or a five inch filter track
Hixheat1 is offline   Reply With Quote
Old 12-27-2010, 06:36 PM   #3
Rewards Points: 280
Not the way I read the description.
States that it is for 1 inch deep air return grilles. So in theory, you could place a 5 inch deep air filter in a 1 inch deep grille. Less restrictive air flow and better air filtering.
But, that is exactly why I'm asking.
Old 12-27-2010, 07:04 PM   #4
Don't think so! If u find it wht is static drop? And wht holds it in place. And how was your filter grille installed I would hope it is oversized. Not as mush as the grille but the depth of the box behind it.
Old 12-27-2010, 07:22 PM   #5
Never saw one like that before Earnie. Looks like a good idea for those with enough room in the duct. Pretty high priced though. A normal honeywell media filter is less then $30.
Old 12-27-2010, 08:49 PM   #6
I think he has a lot of dust, it might be high static he may need a new duct system.
Old 12-28-2010, 06:45 AM   #7
Rewards Points: 280
I'm just looking for options to get better indoor air filtering.
Data I have shows air handler has 1100 cfm air flow. Return air grille has two, 12 inch flex ducts going to the return plenum. Grille is 20" x 25". Air return filter box is 22 inches deep so it excees the minumum 7 inches required to accept the 5 inch thick filter.
I believe I read that it lowers static pressure since its less restrictive.
Yes, very expensive. I've read many reports about the benefits of filters thicker than the standard 1 inch filters. Maybe this filter is something new Honeywell as developed?
Old 12-28-2010, 04:17 PM   #8
I will research for u
Old 12-29-2010, 07:24 AM   #9
Rewards Points: 280
HH1,
That is a very nice offer. Thank you!
Old 01-02-2011, 08:52 PM   #10
Very common...return grille filters, rests in the 1" track with the remainder of the filter inset in the return.
The Honeywell FC40 is a 4" to 5" Filter. Honeywell also has an FC20, 2" version. Drops right into a return grille...the down side...Honeywell only offers standard sizes which sometimes don't fit the grilles of some grille manufacturers; you need a Grille Size Filters. Practical Pleats by Filtration Manufacturing (MERV10) , are another option - most common sizes and an array of custom sizes.
Filters&More is offline   Reply With Quote
Old 01-03-2011, 06:29 AM   #11
Rewards Points: 280
Hi F&M,
Thanks for the link.
So other 5" replacement filters do exist for 1" return grilles. Practical Pleat looks similar to the Honeywell filter.
A very informative but stange website. Lots of product information and ordering links for products, but NO pricing. How do you order product without a price? Actually, I don't think I saw filter sizes either.
Old 01-03-2011, 03:06 PM   #12
An old Tradesmen
Rewards Points: 7,378
The Honeywells you linked to are for 1" filter frames.
however. Your 20X25 filter grille is only good for 800 CFM at 300 FPM. So if you have 1100 CFM goping through it. It should be making noise. If its not loud. Good chance you don't have 1100 CFM going through it.
Old 01-03-2011, 07:21 PM   #13
Rewards Points: 280
Hi BT,
1" deep x 20" x 25" filter is what I currently use. That size was installed with the system so I'm stuck with it. The wall the return grille is in is 6" logs. Not much chance I'll get approval to run the chain saw in the house so we are stuck with that size.
From the system documentaion I have, the air handler is limited to 1000 cfm due to the heat strip package. I have never tested it so I am relying on manufacturer values.
The system does have another air return on the second floor. 16" x 20" x 1" return grille with mostly 10" hard pipe back to the return plenum.
So, in theory, is upgrading the 1" thick filters to 5" thick filters a good idea?
Old 01-03-2011, 08:41 PM   #14
An old Tradesmen
Its an "ok" idea. Best to measure how much static the return has before installing them. But since you don't have a manometer, I would try it in the spring. And see if you have any adverse effects. You don't want adverse effects in the middle of winter.
Old 01-04-2011, 06:54 AM   #15
Rewards Points: 280
Good point. I'll need a new filter by then anyway.
I do have a home made manometer thanks to some info you provided in a past post. Clear rubber hose attached to a white board. Have not used it yet. Too many other projects but checking it is on the list.
Replace Whole House Air Filter kenm09 HVAC 5 02-26-2010 06:17 PM
Hog Hair Filter mjbxx HVAC 10 04-10-2009 08:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
Furnace/Air Filter Cover bcme136 HVAC 14 09-25-2008 06:34 PM
How often shold I replace my air filter? bigboyjoel HVAC 3 06-13-2007 06:05 PM
