4m205j Dayton Motor On AC - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2013, 02:59 PM   #1
4m205j dayton motor on AC
4m205j dayton motor, need to reverse the fan. I took the white plug, pulled it apart and turn one section half way around and plug back together. Now the fan wont turn at all. If I put it back it works fine. Any suggestions?
brit1279 is offline   Reply With Quote
Old 09-06-2013, 03:32 PM   #2
MarginallyQualified
Rewards Points: 2,464
Now the fan wont turn at all. Any suggestions?
Verify the work... then get a new motor.
The Following User Says Thank You to TarheelTerp For This Useful Post:
brit1279 (09-06-2013)
Old 09-06-2013, 03:48 PM   #3
An old Tradesmen
Rewards Points: 6,112
Moved to HVAC forum.
Old 09-06-2013, 04:02 PM   #4
Rewards Points: 77
On the plug verify:
CW Rotation (shaft end)
Black-Black
White-White
CCW Rotation (shaft end)
Black-White
White-Black
Also a bad run capacitor can allow the fan to run backwards.
firedawgsatx is offline   Reply With Quote
wiring a dayton 4m205j no spark HVAC 1 09-25-2012 05:58 AM
4m205j dayton motor wiring? VoltyHawk HVAC 3 05-28-2012 12:28 AM
dayton 4m205j install jb64 HVAC 13 05-07-2012 02:57 PM
Dayton 3E837 Parts Broken Stuff HVAC 3 12-30-2010 09:31 AM
dayton fan motor Turk Electrical 1 02-27-2009 06:38 PM
