410a Charge Calulator By Pipe Size And What Pressors Should Be In R22 A 410a - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 06:34 PM   #1
410a charge calulator by pipe size and what pressors should be in r22 a 410a
I used to have a paper that would calulat the charge for r22 and 410a by pipe size and by the feet of the pipe i lost it wounering if any buddy knows where to find a program our print out calulator for r22 and 410a and can any buddy tell me what the high side and low side psi should be in a r22 and 410a system thanks
ninfreak is offline   Reply With Quote
Old 07-20-2011, 07:28 PM   #2
30 year tech
hvac122's Avatar
Not quite sure what your asking. There are charts from each manufacture as to how much refrigerant needs to be added for longer linesets on installation.
Charging a system needs to be done with superheat and subcooling.
hvac122 is offline   Reply With Quote
Old 07-20-2011, 07:47 PM   #3
i allways charge by Weight and had a chart to go by but lost it if i charge by Superheat (fixed orifice). our Subcooling (thermostatic expansion valve) i forgot what it should be set to beacouse im use to charge by weight
Old 07-20-2011, 08:04 PM   #4
30 year tech
hvac122's Avatar
There is usually a charging chart in the unit as it will vary by manufacture.
Old 07-20-2011, 08:20 PM   #5
An old Tradesmen
Rewards Points: 6,890
So you don't do any service?
