40000 Btu For 500 Sq - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2014, 09:02 AM   #1
Rewards Points: 18
40000 btu for 500 sq
Hi. I'd like to upgrade from electric heat to gas.
I have 40000 btu single stage 800 cfm gas furnance. Can I use it for apartment approximately 500 sq. feet?
Sebas711 is offline   Reply With Quote
Old 11-22-2014, 09:06 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
Do you have an electric furnace now,
You need ductwork and a gas line.
Depending where you live and how drafty the apartment is it may be the right size of it may be too big.
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
The Following User Says Thank You to yuri For This Useful Post:
Sebas711 (11-22-2014)
Old 11-22-2014, 09:43 AM   #3
Rewards Points: 1,640
Too big. I'm in Manitoba and we get quite cold. I heat a 2000sq foot house with an electric furnace. It's 11,000 watts (roughly equivalent to 40,000 btu). Granted I do have a couple of small 500 watt baseboard heaters on the second floor.
Bob Sanders is online now   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 11-22-2014, 09:47 AM   #4
An old Tradesmen
Rewards Points: 6,074
It will short cycle, but you can use it.
The Following User Says Thank You to beenthere For This Useful Post:
Old 11-22-2014, 09:54 AM   #5
Rewards Points: 18
Thank You all.
I live in Staten Island NY.
Old 11-22-2014, 09:58 AM   #6
Rewards Points: 18
Gas will be completed by licensed contractor. Duct work will do my self.
Plan is for one 8 inch round supply, 3 separate 6 inch round supply lines and 16x16 return.
I hope that will work.
Old 11-22-2014, 09:59 AM   #7
An old Tradesmen
1-8" round supply will end up giving you no heat.
Old 11-22-2014, 10:01 AM   #8
An old Tradesmen
A 40,000 BTU input 80 percent furnace should have a 12" round supply if you want to be able to hear while its running. Same with return.
Old 11-22-2014, 10:08 AM   #9
Rewards Points: 18
Thank You. I'll do bigger supply lines.
Old 11-22-2014, 10:12 AM   #10
An old Tradesmen
A 12" round trunk line, or 8X14 rectangular trunk. And 3-7" supplies and 1-6" supply would work okay.
Old 11-22-2014, 10:12 AM   #11
Rewards Points: 18
Is short cycling big problem?
Old 11-22-2014, 10:21 AM   #12
An old Tradesmen
It can wear out parts quicker. Cause you to feel cold as soon as the furnace shuts off, and can use an excessive amount of gas.
Old 11-22-2014, 10:22 AM   #13
Rewards Points: 18
Thank You.
Old 11-23-2014, 08:28 PM   #14
I'd go with a gas fireplace for 500 sq feet.
ahrens is offline   Reply With Quote
The Following User Says Thank You to ahrens For This Useful Post:
Sebas711 (11-24-2014)
Old 11-23-2014, 11:20 PM   #15
Rewards Points: 6,704
For such a small space have you considered a 1 ton mini-split heatpump? (or maybe 1.5 ton with 2 9000 BTU heads)
Today's variable speed mini-splits can heat down to -20c/-4F or lower and use 1/3rd-1/2 the energy of baseboards for the same amount of heat.
Even 40 000 BTUs is far too large. If you're set on a furnace, get a 2 stage 40 000 BTU and lock out high fire.
user_12345a is offline   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Ge 40000 gxsf40h behove Plumbing 1 08-25-2010 08:06 PM
