4 Wire Thermo To 5 Wire System - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 11:04 AM   #1
4 wire thermo to 5 wire system
Hi my old thermostat has five wires and my new controls only has four. There is no connection for the "C" Furnace is a Bryant 90 about 10 years old, have manuals. Any ideas
waboose99 is offline   Reply With Quote
Old 10-27-2011, 11:18 AM   #2
Rewards Points: 268
If the new stat runs off battery power, it will not need the C wire.
JackDidley is offline   Reply With Quote
The Following User Says Thank You to JackDidley For This Useful Post:
waboose99 (10-27-2011)
Old 10-27-2011, 11:25 AM   #3
4 wire therm
Thanks so I just leave the C wire off, cap it? A YouTube video says the batteries will only last 20 hours. Furnace and original thermostat are about 11 years old, the new programmable unit is about 5 noma 52-2557-0
Old 10-27-2011, 12:10 PM   #4
Rewards Points: 6,652
I would take the thermostat back and get one that powers off the 24v on the furnace. No need for batteries to die when away from home, and then come home to frozen pipes.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 10-27-2011, 12:19 PM   #5
Rewards Points: 268
I had a battery operated stat in the past. I changed the batteries once a year and they never went dead. I currently have one that has both batteries and 24 V power.
Old 10-27-2011, 12:33 PM   #6
biggles's Avatar
doesn't a stat with no C on the subbase run off a back feed from the TR,and the batteries are for a no power situation... to save the back up the info for the program?
The Following User Says Thank You to biggles For This Useful Post:
Old 10-27-2011, 01:20 PM   #7
thanks to everyone who replie
Again thanks to everyone who replied, this was my first venture into these chat sessions. Fist problem is the Stat, bought two about five years ago so I can't take it back. Can anyone verify that it runs on the hot wire transformer and the batteries are just for backup like some else has said. The other Stat that I installed worked fine, four wire system and the batteries lasted a long time. Logically should this unit not get it's power from the red hot side of the transformer with the other three wires being, ground, heat relay and cooling relay? Is the fifth wire, the C just bring power from the furnace to power the Stat or does it have another purpose
Old 10-27-2011, 03:47 PM   #8
biggles's Avatar
for years after stats got electro mechanical even they worked on the back feed of the R hot to run the mechanical clock and some a digital clock with a small display.but now the vision pros and such need a direct 24Vs R/C readable at the subbase without the stat up just furnace toggle up.if you get a R/C stat and don't have a C the stat would light up but just sit with no internal relay action because of the missing C and the back feed just couldn't swing it.maybe the batteries power the digital led only..what happens with out batteries when its on the subbase..
Old 10-27-2011, 04:57 PM   #9
An old Tradesmen
Rewards Points: 6,080
No, they use the batteries. A digital thermostat with no C and no batteries uses power from the system by bleeding a small amount through the W and Y terminals.
Installing a five wire intercom station on a four wire system Vnice82 Electrical 1 07-05-2011 06:36 PM
Connect a 2 wire grounded out let to a 2 wire ungrounded wire cable FranH70 Electrical 2 04-25-2011 01:59 PM
Electric Run, Voltage Drop Issues. Eventual upgrade of system this year. lawnphysics Electrical 4 04-06-2011 07:24 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
