4 Ton Unit 3000 Sq Ft - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 09:35 PM   #1
Rewards Points: 31
4 ton unit 3000 sq ft
Will a 4 ton york unit be overkill for 3000 sq ft house? House was built in the 90's.
Willis
shoothebunnies is offline   Reply With Quote
Old 05-26-2011, 10:02 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
have a load calculation done. its the only way to know what size will work for your home.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-27-2011, 11:49 AM   #3
+1.
I'd say, off the top of my head, probably not. You might even need more. Where do you live?
pjpjpjpj is offline   Reply With Quote
The Following User Says Thank You to pjpjpjpj For This Useful Post:
shoothebunnies (05-27-2011)
Old 05-27-2011, 01:06 PM   #4
Rewards Points: 31
Minneapolis Mn
The house was built in 1999.
Here is the information on the unit that is currently hooked up.
Manufacture - Heil
On the sticker it noted two model numbers: ACS036A2C1 and FBA036GC1. Serial number is L984268319.
Anyone know what size unit I currently have?
Old 05-27-2011, 02:46 PM   #5
Rewards Points: 6,652
You really need to do a manual J. Mine house was built in 1937, has no insulation in the walls, double pane windows, air leaks sealed, 850sqft, 1700 if you include the basement, so a 2 ton works fine for mine. 1.5 was the min, 2.5 was max that would work, so hard to say.
Old 05-27-2011, 02:52 PM   #6
You have a 3-ton unit. The "036" is MBH (1000s of Btuhs) and is standard nomenclature for most AC manufacturers - a ton is 12,000 Btuh, or 12 MBH - so divide 36/12 = 3 tons. A 3.5-ton unit would be "042", a 4-ton unit would be "048", etc.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
