4 Heat 2 Cool Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 11:54 AM   #1
Question
4 heat 2 cool thermostat
Have a Trane 2 stage heat pump and 2 stage natural gas furnace. Need a thermostat to fully take advantage of this set-up. Currently have a Vision Pro which only works for 3 heat and 2 cool. Do I need 4 heat 2 cool or will mine work?
poordebru is offline   Reply With Quote
Old 02-01-2010, 07:04 PM   #2
An old Tradesmen
Rewards Points: 7,414
If you want full control of the aux stages. Then yes you need a 4 heat and 2 cool thermostat.
Such as the Honeywell IAQ thermostat(YTH9421).
Moved thermostat - Now no heat. Bernan HVAC 2 11-15-2009 12:16 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
vent sucks cool air instead of blow heat wayneled86 HVAC 3 01-25-2009 10:10 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
