3Amp Fuse On Fan Board Blowing! - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-30-2014, 05:55 PM   #31
Rewards Points: 12
Looks like the blue wire does in fact energize the contactor from the defrost board...it is on the same connector as the reversing valve.
russkateer is offline   Reply With Quote
Old 08-30-2014, 05:58 PM   #32
Rewards Points: 12
Are we making any progress? Seems like the problem has been isolated to the defrost board...specifically in the RV circuit or the contactor energizing circuit. Any thoughts?
Old 08-30-2014, 06:59 PM   #33
Rewards Points: 197
bad board/new board
CWO4GUNNER is offline   Reply With Quote
Old 08-30-2014, 07:00 PM   #34
Rewards Points: 3,256
Whichever board, circuit, etc, that Y and O have in common is most likely the problem as you said either one of those signals blows the fuse.
zappa is offline   Reply With Quote
Old 08-30-2014, 08:47 PM   #35
I'm Your Huckleberry
Rewards Points: 2,270
check the plugs on the defrost board which feed the rv to ground and to each other.
or give rv 24 volts from 24 to heat pump directly. or pull off defrost board and look on back for burn marks.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-03-2014, 09:48 AM   #36
Rewards Points: 12
OK, finally got back to this...been cooler so not as high a priority.
Interesting note, I connected everything back up and tried heat from the thermostat ( I believe I had manually called for it jumpering, which blew the fuse) but contactor pulled in and everything fired up.
That puts all my eggs in the RV or RV circuit as being bad...I think. I pulled the defrost board out (which has the RV circuit) and I don't see any bad components...or burn marks.
Do I just buy a new board and cross my fingers? If it is the RV then I'm out of my league anyway.
Old 09-03-2014, 09:56 AM   #37
Rewards Points: 12
Pretty sure this is not good...everything is working now. Even ac...the HVAC elves came over the weekend?
Probably not the last you will hear from me. I didn't change any components, just fuses and checked stuff. What do you all think?
Old 09-03-2014, 10:23 AM   #38
Rewards Points: 197
You'll probably go through another bout of blown fuses as soon as whatever stressed the weak link reaccurs. I also now that when you test for heat whether for an RV or furnace in summer time your asking for the system to act up. Why our local HVAC lab classes reserve the heating portion of the lab classes for winter. Otherwise nothing worse right.
Perhaps in your case someone accidentally called for heat (in summer) momentarily at the thermostat staring this whole issue.
Old 09-03-2014, 10:46 AM   #39
Rewards Points: 197
I think I already said this but I had a similar problem in rental and after testing the capacitor which tested good, and exhausting all other avenues I could think of, replaced the blower capacitor with a spare I had on hand, and that was it, a bad cap that tested good made in China. I would swap with the spare or if more then 5 years old swap out cap and contactor'sanyway for ppreventative maintenance. I do every 5 years caps and contactor's.
Old 09-03-2014, 03:01 PM   #40
An old Tradesmen
Rewards Points: 8,154
Its his low voltage fuse that is blowing. not a line voltage fuse. So a bad capacitor for a motor won't cause the problem he is having.
Old 09-03-2014, 07:14 PM   #41
Rewards Points: 197
Believe it or not, you just made my point.
Old 09-03-2014, 07:32 PM   #42
Rewards Points: 12
Old 09-04-2014, 12:03 AM   #43
disconnect the o/b wire from stat and run system through stat. if nothing blows, rv is bad. granted do not expect to have cool on call for cool or heat while on call for cool with reversing valve wire unplugged, but if nothing blows than that's your problem, rv.
Thanks.
Tags
fuse , heat pump , hvac
100 AMP Fuse Blowing on Service Disconnect on One Phase actormike Electrical 17 12-10-2013 03:28 PM
Micro Wave Oven blowing circuit fuse jankencanada Electrical 5 12-23-2012 12:47 PM
2 week old Amana APG13M blows board fuse 95ponymobile HVAC 13 12-02-2012 09:42 AM
dishwasher keeps blowing fuse funkjosh Appliances 12 10-31-2012 11:32 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
