36 Foot Flex Duct. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 04:26 PM   #1
Rewards Points: 280
36 foot flex duct.
I have an older 2 ton AC system in FL. I would like to add a duct to supply a 12X15 room. Is it possible to run flex duct 36 feet from the plenum to a new room, if so what size??? Would it be worth trying to see if it works?? The option's are window AC, mini split or replace whole system.
JIm
jjrbus is offline   Reply With Quote
Old 05-28-2010, 04:44 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
You can run it and would need at least 6" but you are robbing Peter to pay Paul. If your system is older and does not have any extra capacity the rest of the house will suffer. You may want to do a heat load calculation to find out what size system you need:Load Calculator
The new units are more efficient and in your climate that may save you a lot of $$. There may be some gov't rebates to help you.
Old 05-28-2010, 05:53 PM   #3
An old Tradesmen
Rewards Points: 7,412
36', thats a long run. A 12X15 room could need an 8" depending on how straight the run is or isn't.
Old 05-28-2010, 06:48 PM   #4
Rewards Points: 280
Thanks for the responses. I should have added that the general opinion is that my current duct work is too small. The main duct off a 2 ton unit is duct board and has an outside dimension of 12X12 inch. I have no idea how thick the duct board is. It is feed by what appears to be 10" flex. This feeds 6 outlets in what is currently (without new room) a 780 sq ft house. the new room is 12x15 and will make the total area 960 sq ft.
According to their rule of thumb it takes 1 ton to cool 500 sq ft in this area and this type of house.
I truly appreciate your input, I know nothing about HVAC and cannot say I am overly impressed with the contractors I have met. One was pretty good but he does not want the job.
JIm
Old 05-28-2010, 07:01 PM   #5
Registered User
Rewards Points: 5,520
Interesting tidbits on flex: http://rockwallcontrols.com/Resident...ag=air-ducting
http://www.mmmfg.com/pdfs/True_Cost_...x_10-27-06.pdf
Do not read this when tired: http://www.thefreelibrary.com/Pressu.....-a0201591046
Be safe, Gary
Old 05-28-2010, 07:11 PM   #6
An old Tradesmen
Your duct board is probably 1" thick. Making it 10X8 duct, which is too small.
Old 05-28-2010, 07:56 PM   #7
I live in Florida and I am in hvac. i recomend that you get the a new unit if your's is more than 12 yrs old. In the long run it will save you money. I would have to agree that you'r ducting is to small. But yes you can run flex that far but I would recomend that you also put a return in the room if possible. I would go with an eight inch supply in a room that big.
Secondgear is offline   Reply With Quote
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
flex duct termination issue LanterDan HVAC 2 02-12-2009 05:59 AM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 08:07 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
