34 Man Hours To Install Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 09:54 PM   #1
34 Man Hours to Install Gas Furnace
I was just billed for 34 man hours to remove old furnace and install a small 85% efficient boiler at a house I own in PA. Old furnace was oil, but gas line was already in basement, within 20 feet of the new furnace. I wasn't around for all of the work, but this seems like a lot of hours. Furnace was vented directly outside of basement, and not through chimney.
pmb151 is offline   Reply With Quote
Old 02-13-2012, 09:58 PM   #2
Rewards Points: 14,312
Do you not have a signed contract stating what it was going to cost to install? If not shame on you.
hvactech126 (02-13-2012)
Old 02-13-2012, 10:08 PM   #3
a picture is worth a thousand words......
dosy777 is offline   Reply With Quote
Old 02-13-2012, 10:11 PM   #4
Rewards Points: 582
agree with dosy seeing is believing....show us what you got .....will tell you what to do
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (02-13-2012)
Old 02-13-2012, 10:12 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
So about 7k for an oil to gas conversion including equipment? sounds about right.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-14-2012, 04:36 AM   #6
An old Tradesmen
Rewards Points: 8,236
Hot water or steam? Copper or black pipe for the boiler piping? Single or multiple zone system? Black pipe of CSST for the gas piping? Upgraded to meet code or not? Chimney liner installed also? How old, and what size was old boiler?
Old 02-14-2012, 05:45 AM   #7
Rewards Points: 1,216
If you really think about it this way it don't seem like to many hours. 2 men 2 days = 32 hours so I don't think it's out of line. Of course I don't know what the job details were and you should have had a bottom line contract before the work began.
COLDIRON is offline   Reply With Quote
Old 02-14-2012, 06:35 AM   #8
HVAC Tech/ Browns Fan
You should of read it but still we cannot see what they saw in the replacement. Some times if job looks like its going to take longer and be more harder you all ways bid high so you don't lose money. Plus you should of got couple more quotes on it to compare price's.
Tator1076 is offline   Reply With Quote
Old 02-14-2012, 08:28 AM   #9
biggles's Avatar
you went from hot air to hot water/steam heating was baseboard or rads installed in the spaces
New furnace and a/c coil install done raylo32 HVAC 4 10-05-2011 07:46 PM
Furnace Install Cost jrppa8 Off Topic 5 10-03-2010 02:48 PM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
