3 Wire Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 11:57 AM   #1
Unhappy
3 wire thermostat
I am trying to replace a broken thermostat. It is a 3 wire White Rogers, one of three zones to a hot water boiler heating system. One wire is red, one is blue, and the last is white. Every thermostat (programmable) I buy has slots for 4 wires. Can I leave a slot open? I don't have a cooling system.
shadow82399 is offline   Reply With Quote
Old 09-20-2009, 04:29 PM   #2
For a three wire zone valve, the stat needs to have a contact that closes when when the call for heat is complete. The zone valves power open with a call for heat and power closed when the call for heat is satisfied. The average 4 wire digital heat and cool stat will not work for this application. There are some that will accomplish this but are usually more high end.
SKIP4661 is offline   Reply With Quote
Old 09-20-2009, 05:30 PM   #3
So what can I replace the thermostat with? One is completely shot, the others are just really old and I would like them updated.
Old 09-20-2009, 08:37 PM   #4
An old Tradesmen
Rewards Points: 6,570
White Rodgers has stats that you can use. Don't remember the mod numbers off hand.
You may want to search their website.
Tags
3-wire , heat , thermostat
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Which thermostat and how to wire it! woodworker2 HVAC 1 09-18-2008 09:18 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 08:14 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
