3 Ton Heat Pump Split 10 Seer - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 06:18 PM   #1
DKS
3 ton heat pump split 10 seer
have a unit that one day it runs fine,and then later it doesn't. pressures are 70/250 new filter.unit was low and injected w dye found signs of dye near acess ports but nothing confirmed weather it was blow bk from disconnection or leaking? i'm thinking maybe limit switch .don't know alot on cycles of a heat pumps,do they go into defrost during summer?
DKS is offline   Reply With Quote
Old 07-12-2011, 09:01 PM   #2
No defrost in the cooling mode. High pressure switch trips around 400 psi so 250 shouldn't be an issue. Subcool and super heat checked to confirm charge and txv operation? Capacitor checked? Amps checked on condensor fan motor? Float switch on the condensate line or pump? Intermittent problems stink!
Old 07-13-2011, 10:15 AM   #3
DKS
Yeah it makes for a long day on a roof when it won't show it's evil side. Just got to baby sit til it does,i guess. Will post what i find later
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Suggestions for a 5 ton split heat pump purchase? kurtibm HVAC 1 07-07-2010 11:47 AM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
