3 Room Addition Isnt Getting Much Airflow. Help!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 10:44 PM   #1
3 room addition isnt getting much airflow. Help!!!!
We just added a 3 room addition. Two bedrooms that are 11x14 and a den that is 8x16. the problem is that the ducts i put in aren't cooling the area very well. I'm not sure of furnace type but i will get it. Each room i added a 6" flex duct from main trunk, which is in the basement, and ran them to basement wall which the lengths vary from 10' to 23'. Then i reduced to a 4" flex which runs in crawl space for the remainder of the distance, which varies 8' to 16'. They then run into a 4"x12" register on the floor. Why am i not getting any airflow to cool and heat these rooms? Any help would be much appreciated. Thanks
mfkj is offline   Reply With Quote
Old 06-25-2009, 11:11 PM   #2
as seen on tv
Rewards Points: 150
Very poor duct design
qbert is offline   Reply With Quote
Old 06-26-2009, 08:01 AM   #3
An old Tradesmen
Rewards Points: 6,112
Each of those runs, is almost big enough, to do a powder room.
For those long runs, should have been 8".
Should have actually ran a trunk line into your crawlspace, and then used flex duct from it.
Old 06-26-2009, 09:41 AM   #4
30 year tech
hvac122's Avatar
Is this a joke?
hvac122 is offline   Reply With Quote
Wood subfloor with slab room addition pfrech Flooring 2 01-08-2010 10:49 PM
Poor airflow to living room mainstreetprod HVAC 8 01-16-2009 09:13 PM
Tapping into AC Vent for Room Addition wonderworm Building & Construction 2 06-26-2008 12:26 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Question: second story addition to existing room elmorem@gmail.com Building & Construction 3 02-17-2008 10:38 PM
