3 Phase Motor Help - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 08:07 PM   #1
Rewards Points: 484
3 phase motor help
Hi all. I have installed many 5 horse power 3 phase motors in the past for large swamp cooler applications but encountered one this afternoon that I'm confused with.
When I removed the cover plate on a brand new one today that I need to wire, it has two small extra red wires and on the wiring diagram, it says "hook red wires to thermostat."
Does anyone know what they mean by this? Am I supposed to wire something in for overheat protection?
This is a simple replacement for a cooler that lost a motor on a warehouse that I service and none of the old motors have these extra two wires. Thanks
sammy37 is offline   Reply With Quote
Old 05-01-2012, 09:00 PM   #2
Rewards Points: 27
Those 2 small wires are for the built in thermal switch. You should be able to read continuity through those 2 wires with a meter. If the motor overheats the thermal contacts would open and then, if wired into the start/stop circuit, would drop out the motor starter to keep the motor from burning out.
Sometimes though it could be too late but it's just another form of motor protection besides fuses and overload trip devices. You can just tape them up and not use them. (be sure the fuses and overloads are sized properly)
Generally these are N.C. switches (normally closed) but where I work we once had a conveyor system with several motors and each motor had a N.O. switch (normally open) when a motor got hot the switch would close and light a corresponding lamp on a control panel to indicate which motor was hot.
(problem was, if it cooled off before you looked at the panel the light would go off!)
fredm54 is offline   Reply With Quote
Old 05-01-2012, 09:35 PM   #3
there is also the slight chance that these are motor heater leads but 99% likely these are for thermal overloads.
itsnotrequired is offline   Reply With Quote
Old 05-01-2012, 09:37 PM   #4
Rewards Points: 616
they are for inherant motor protection....
carmon is offline   Reply With Quote
Old 05-01-2012, 10:24 PM   #5
Rewards Points: 484
Thanks guys. I usually see starters on these large motors but this building in particular has none on these coolers.
hELP! Amperage needed for 220V motors 1488rob Electrical 36 01-28-2014 04:44 PM
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
